Tapered Column and Beam
Hello All,
I am trying to create a tapered mainframe column and beam system.  I have done many searches on this issue and have not found what I want, at least not the easy way.
I found a tapered column family and it seems to work the way I want it to.  I have then created a tapered beam from the family ootb file Structural Framing – Beams and Braces.  I have changed some of the parameters since I didn't all of them.
Then I created an extrusion using blend –>>(base) beam attached to column -->> (top) beam end.  I attached some parameters within the blend.  This is working the way I wanted (I think).  Now I insert the beam as a structural framing component and pick the grid line and lock it.
This image shows a space, which I did intentionally..this configuration works when I change the dimension of the grid spacing...
Before I did that, I created a named reference plan for the top of the beam to align to.  That seems to work.  I want the column and beam to be on the grid line and locked to it so I can change the grid spacing and they move with it.
But.....
Then I try to move the end of the tapered beam to the face of the tapered column.  I do not attach or align, I just move it to where I want.  After doing that, I try moving the grid line BUT this is what happens.
Any ideas?  If you need more detail of what I did, feel free to ask.
OR - is there a simpler way of doing this or is this part of the program to make these?
Thanks in advance...
Jleibold
Rafal.Gaweda
Autodesk Support
Autodesk Support
You may consider doing this by Cut command.
Example:
Rafal Gaweda
The video looks amazing but I cant find the "Extention" tab.
Any ideas?
Regards
ryanKVSBP
What revit extension is used in this video?
ashwania426
Community Visitor
Community Visitor
Hey,
i have created a parametric tapered column using blend...but when i tried to apply base plate on it , it is not accepting any solution for this??
Ignus.E
Hi. You would need to build a base plate connection family using the normal Revit family creation way, as tapered columns and beams is not supported by the Revit connections
ashwania426
Community Visitor
Community Visitor
Hey. thankyou sir for this information
