analytical model
analytical model
A_MAQ
Advisor Advisor
analytical model
A_MAQ
hello all ,
is the analytical model which i get it from revit applicable to have an exact design results in robot structure or athor softwares ?
actually all the consultans company in my country does not take the analytical model from revit to have a design results
i do not why
Is that due to the lack of accuracy of the results؟
thanks in advanced
Autodesk Expert Elite
A_MAQ
any reply ?
bjoern_teutriene
Of course you can use the analytical model from Revit and export it to FEA Software like Robot or SOFiSTiK. You just have to adjust the analytical model and add some loads + supports in Revit. You can find a video about a exemplary workflow here. Many Revit users are already working like that.
Why do you think there would be a lack of accuracy within the results?
Beste Grüße
Björn
Senior BiM Consultant bei
www.bimotion.de
E-Mail | LinkedIn | YouTube
A_MAQ
first of all thanks a lot
second thing that a large companies in our countries does not use it
AGYEMANG.OFOSU
if they are not using it, it only means they have other means of getting results and that shouldnot be a bother.  Revit as a tool is great and it facillitates work. you must know how to implement it in your workflow.
