Surface development of truncated con
How I can make or generate a cone surface or a truncated pyramid?
I have a pole and I want to find out the dimensions of the steel plate to make that pole.1.JPG
ovidiu_paunescu
Maybe this can help https://library.vuforia.com/articles/Solution/Cylinder-Targets-Guide
At least for calculating the dimensions of the plate that wraps around to form the truncated cone.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Judy_S
Hi, mihaela.maftei,
I'm Judy from Revit Support, and I see you're looking for way to make a truncated cone in Revit. You can use the Revolve tool to create that shape. The Revit Help page called Create a Revolve will show you how to do this.
Please let me know if this helps!
Judy_S
Judy.S
Product Support Specialist, AEC
Link Name | Link Name | Link Name | Link Name
I would like to know how to create surface development of truncated con, if I already have truncated con. If it is possible to generate automatically, I'm currently drawing with the Detail Lines, I need to know the dimensions of the steel plate from which the truncated con will be made to send it to the factory.
ovidiu_paunescu
You can manually compute the size of the unfolded sheet by using the instructions in the link i shared above (towards the end of the article).
You can also do it in Inventor
https://youtu.be/N-dX2qd3rCQ
