section box
section box
section box
I am at the moment having some doubts about the rebar that composes the retaining walls, and I need to select them. My question is, can I isolate this ones? My first ideia was to create a "void" inside the section box, like you see thought the picture, because the filter option doesnt work, because it selects all the rebar, it doesn´t differentiate between the wall rebar or the foundations rebar. Any thoughts?
best regards
corkybenle1
what if you turn off the foundations in the view so they are not visible
then
with having only the walls and wall rebars visible, change the wall transparency to 40% so you can see thru them
then
select everything and filter by rebar
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
