Structure Wall
Structure Wall
ihsanhalim28
Message 1 of 8
Structure Wall
ihsanhalim28
Hello, I want to ask, why does my wall have an opening/void while the profile wall is full
Replies (7)
Message 2 of 8
ennujozlagam
difficult to tell? in 3d view activate your bulb icon, it could be the there is wall in between that is hidden? or void mass in-place?
Message 3 of 8
ihsanhalim28
no sir when i turned on the bulb to reveal the hidden object
Message 4 of 8
alan.johnson7YLND
Can you share your project file?
Message 5 of 8
alan.johnson7YLND
There could be an architectural element (wall) intersecting
Try changing the discipline to coordination.
Message 6 of 8
boliveira625L4
I had the same problem a while ago, I saw something hidden that was not shown on the bulb of hidden objects, this is because the file was using phasing to control elements in the view when I turned it all on, I could see a wall going through my structure and causing the problem
Message 7 of 8
alan.johnson7YLND
Without seeing your file it could be either an architectural wall or a structural wall in a different phase that was drawn first, then when your structural wall is drawn intersecting it, there is a gap showing.
So you need to check for an Architectural wall or a Structural wall in a different phase
Message 8 of 8
JoshuamRivera
Thanks for sharing, It can be due to a setup with Phasing, review those options/controls. Another thing can be going to your 3D view under Graphics properties , Show Hidden Lines options to switch the elements by discipline and so on.
Best wishes
Joshuam - Structural BIM VDC Design Director
Feel free to Like this post if you find it to be helpful.
Click on the ACCEPT SOLUTION button if your question was answered.
acad logo.jpg Contributor
