Structural connection settings not appering
wbchibaka
wbchibaka
Community Visitor
Community Visitor
I am using revit 2020 and i want to load connection types to my model but when I click the arrow on the lower right of the connection panel to bring up the structural connection settings the following message comes up:
"A serious error has occurred. The current action has been canceled. It is recommended that you save your work in a new file before continuing.
Would you like to save a recovery file?"
Please help out with any solution or other means to add connections.
ennujozlagam
try to install latest updates from autodesk and see if helps?
