Structural Section Properties
Message 1 of 10
Is it possible to calculate I, A, J in Revit?
Replies (9)
Message 2 of 10
catalin_lang
Just to be sure, what do you mean by I, A, J in Revit?
catalin.lang
Message 3 of 10
A_MAQ
I = Moment of inertia
A= area
j= factor related to column slenderness
Is that right?
Autodesk Expert Elite
Message 4 of 10
Yes,
I know that the area is calculated with a filled region but I am wondering if the moment of inertia can be calculated in Revit.  It is done easily in Acad.
Message 5 of 10
catalin_lang
For a structural element, I, A, etc. are type parameters and are loaded from a database.
The only calculated parameter, somehow close to what you need, for a structural element, is the Volume.
Do you need to have these parameters already calculated, as for the Volume?
or do you think you need a "tool" that allows you to easily get these values?
catalin.lang
Message 6 of 10
A_MAQ
you can go to  your family and add a parameter for moment inertia which will be calculated based on the section dimensions,
Message 7 of 10
Easy. Need sross section points
Message 8 of 10
A_MAQ
for example
Ix = b h3 / 12
where b=width of cross section, h = height of cross section
so inside the family you can create a parameter called IX , and the value of this parameter will be a formula equal to Ix = b h3 / 12
Message 9 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Or in case the section is complex, you may use Autodesk Robot Section Definition module to calculate properties and then rewrite calculated values to Revit family parameters.
See this.
Rafal Gaweda
Message 10 of 10
public static double PolygonArea(List<Point> points)
var pointsCount = points.Count;
double area = 0;
for (var i = 0; i < pointsCount; i++)
area +=
(points[(i + 1) % pointsCount].X - points[i].X) *
(points[(i + 1) % pointsCount].Y + points[i].Y) / 2;
return area;
