Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Structural Framing Family - Length and Copying Issue
1 REPLY 1
mpfranco88
1343 Views, 1 Reply
Hello. I created my first beam family and place it as a structural framing which is a simple concrete beam with an "L" shape. I need to creat a "wall" made out od these beams with a 2 meter section each and when I first place it there is no issue but later when I copy and paste them using the Revit tools, the dimension change and doesn't move nor aligned properly, as well as the witness lines seem to be chosen randomly. I believe there might be a problem with the reference planes the moment I created the rfa but I am unsure. I post the rfa for reference.
Thank you.
1 REPLY 1
Avaris.
in reply to: mpfranco88
I downloaded your .rfa but everything looks just fine. Structural framing is just like walls; it likes automatic joining. Try to unjoin (right-click the blue dot at the end) and then copy.
Forma Design Contest
