Structural code checking - no code registered - where to download code from?
Priitl220
Priitl220
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
awes
Priitl220
I have downloaded the toolkit. How would I get this error without it?
Running the code checking gives me the error and tells me to download something additional. Where can I get that?
From toolkit help.
Usage
Before you use the structural code checking tools, check that the following requirements are met:
  1. You have structural analysis results inside the Revit® project.
    Tip: Click Analyze tab Structural Analysis panel Results Manager to check that the results are saved inside the Revit project. DONE
  2. You have registered at least one code checking application.
    Note: Code checking applications are add-ins that you can download on the Exchange app (http://apps.exchange.autodesk.com/RVT/Home/Index) website.
    HOW can i register?
    WHAT to download in addtion to this "Structural Analysis and Code Checking Toolkit 2014 "?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please check http://forums.autodesk.com/t5/Autodesk-Revit-Structure/Structural-Code/m-p/3897841
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
iliribraimi
