Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Structural Area Reinforcement issue at slab edge representation
2 REPLIES 2
rafaelPD66Z
197 Views, 2 Replies
Hi everyone, there is an issue about Area Reinforcement that I hadn't solved and I would like to read your opinions. Every time I create an Area Reinforcement the bars at the edge of the slab don't look like I think they should look like in the real life.
That last bar should be outside but inside the cog of the transversal bar.
Something like this. Is there any way to make it looks like the second image without detailing it up?
This is the configuration of the Area Reinf. Thank you so much
Tags (2)
Labels (4)
2 REPLIES 2
If you are on Revit 2023 check the image belwo it will edit and get exactly what you need
Ahmed_Muharram_0-1670662035284.pngAhmed_Muharram_1-1670662068367.pngchange the dims to be 250 for exampleAhmed_Muharram_2-1670662079560.png
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Excellent Ahmed, I think Revit should solve this automatically, but while that doesn't happend this solution is perfect. Thanks a lot
Forma Design Contest
Technology Administrators
