Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Structrural Framing Not Visible In Coarse View
10 REPLIES 10
Message 1 of 11
8242 Views, 10 Replies
I am working on a simple structure in Revit.
I worked in Fine Detail view.
Everything works great, only problem is when I switch to Coarse detail view the beams all disappear.
They are still there but not visible in Coarse view
Any ideas?
10 REPLIES 10
Message 2 of 11
MostafaElashmawy
Hello @Anonymous,
The beams are there in the coarse level of detail but in a simplified way "something called symbolic representation"
you can control what will show in each detail level from inside the family it self.
Edit the family,select the sweep or extrusion forming the beam, then click on visibility settings and tick the mark in front of coarse level.
Kindly check the attachments for more clarification.
let me know if that resolves your problem.
Mostafa Elashmawy
Message 3 of 11
Edit: never mind, looks like we all misunderstood your query
Instead of modifying each and every beam and other members at the family level, I would simply change the view's visibility graphics overrides (VG) to make the structural categories show in Medium or Fine, independently from the view's detail level.
Message 4 of 11
in reply to: MostafaElashmawy
I only want the "stick" version .
I tried the way you proposed but it makes the beam as if it were in Medium Level of Detail.
Message 5 of 11
Are you working with a structural template?  Can you share the file?
Message 6 of 11
in reply to: ToanDN
View Template is set to None,
I'm afraid I can't share the file.
I worked previously on similar project, beams would simply appeared as "stick" in coarse view, I can't find why they are disappearing now.
Message 7 of 11
MostafaElashmawy
if the family don't have the stick symbol, you can draw a line inside the family and set it to show at coarse views.
make sure that you lock the line to the left and right reference plans inside the family.
Mostafa Elashmawy
Message 8 of 11
Check the view range and make sure the Range cover the entire beam height.
Message 9 of 11
jbrazier
Is your Discipline set to "Structural"?  If it's set to Coordination or Architectural the beams will be hidden by any floor elements.
Jon Brazier
Director of Production Technology
O'Donnell & Naccarato
Philadelphia, Pa.
Message 10 of 11
Attached is an example (2018) with the same behavior.  Check your view range.
Message 11 of 11
it works well.Thanks
Forma Design Contest
Technology Administrators
