Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Steel connections
2 REPLIES 2
thiago.ribeiro4TG7Z
250 Views, 2 Replies
Steel connections
Hi, Folks
I'm new in steel modeling and I would like to know wich type of connection I should select for this one showed in the pic below. There's a bracing(CH) connected with two other beams(VM).
2 REPLIES 2
check out these types of general bracing
if it didn't work you have to draw it manualy
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Hi @thiago.ribeiro4TG7Z,
Welcome to the Revit Structure forum. Thank you for submitting your question in our discussion forums. It looks like Ahmed's suggestion to specify the structural connections via the Structural Connection Settings may help, so for now, I will mark his reply as the "Answer." This won't prevent other folks from commenting on this question though, in the event other ideas come up!
Please let us know if you require further assistance.
Remember to mark your posts as having an "Accepted Solution" if a solution is found as it helps other forum users with the same issue – so don't be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems. . You could unmark the post as an accepted solution if the solution did not work. Click the ellipsis menu  > Not the Solution to cancel an accepted answer.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
Forma Design Contest
