Steel connections
Steel connections
I am trying to use the steel connection Revit 2022. Revit will cut the beams, columns as if it is going to show the connection, even showing bolt holes, BUT does not show angles, plates or bolts relating to the connection & when I have tried to drawing a plate myself i.e. for a fin connection it again wont show the plate.
Rob_Merriman
Hi @Anonymous
You need to be in Level of Detail - Fine to see plates, bolts etc from steel connections
There is also a new Visibility graohics category called connections, if you expand that make sure all sub categories are ticked
Rob Merriman, AEC Technical Lead, Graitec
It was the visibility setting thankyou
