Revit Rebar Schedule Total Mass Problem
f.kirmizidag
f.kirmizidag
Dear all,
I created a schedule for rebars. But if i set Calculate Total, Mass parameter (Masse) gets higher than actually is. It is multiplied by random parameters which i cannot obtain what it is. I couldn't figure it out. I get wrong total mass eventually. I'd be appreciated if someone help me.
RDAOU
@f.kirmizidag
Under sorting and grouping ... Check the itemize every instance check box
When it is unchecked and you calculat totals => u get the total per type
