how to have bolt with double nuts?
jesvicnaag08
jesvicnaag08
Our firm usually put double nuts in our steel connections. Is it possible to have a bolt with double nuts in revit?
ennujozlagam
what do you mean? show some screenshot here? otherwise you can edit the family and make it double nuts?
2D or 3D family?  Either way, yes, you just have to edit the family.  Easier said than done most of the time.
Rob_Merriman
hI @jesvicnaag08
If you are using connections from the steel tab they are not based on families, everything from the steel tab comes from Advance Steel and is database driven not family based.
To change the number of nuts / wahsers you need to select the "Assembly" in the joint dialogue, see screenshot below for example W+WN mean washer on the head of the bolt and a washer and nut on the other side
These databases are stored in the following location - C:\ProgramData\Autodesk\Revit Steel Connections 2022
You will need Advance Steel installed and then modify the bolts in Advance Steel to add the nuts etc
Before you do any modifications to the Advance Steel anchors i would strongly recommend becing up the Advance Steel data, check out my blog post on how to do that - https://www.graitec.co.uk/blog/entry/are-you-backing-up-your-advance-steel-data
This is an excellent video from Autodesk on how to customise the bolts etc
https://www.youtube.com/watch?v=gGCvrv2vIVM
Once you have your new nuts with extra nuts you need to get them into Revit, all the Revit bolts and Anchors are taken from the Advance Steel databases which have been copied into the Revit folder Structure, so you need to copy the Advance Steel Database with the new bolts and paste it into the Revit folder structure. Please follow the steps below (Again please note i am working on UK builds so the fodler paths will be different)
1. Shut down Revit and Advance Steel
2. Go to the following folder - C:\ProgramData\Autodesk\Revit Steel Connections 2022\en-UK
3. Rename the AstorBase.mdf to AstorBaseOriginal.mdf (Always best to have a backup)
4. Delete the file AstorBase_Log.ldf
5. Go to the following folder C:\ProgramData\Autodesk\Advance Steel 2022\GBR\Steel\Data
6. Copy the file AstorBase.mdf and paste it into C:\ProgramData\Autodesk\Revit Steel Connections 2019\en-UK
7. When you reboot your Revit you will now have the nuts that you created in Advance Steel available inside your Revit Base Plate connection
Rob Merriman, AEC Technical Lead, Graitec
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
