Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Steel Beam Connection to Wall
3 REPLIES 3
chrisd
362 Views, 3 Replies
I've just started dabbling with Revit Steel Connections. We do many tilt-up precast panel wall projects which in real-life have steel cast-in-plates embedded in them.
In the screenshot below, the beam on the left is my reality, the beam on the right is a mock-up of what I want to achieve (I put a column there just to be able to create the cleat plate & bolts).
Is it possible to create a revit steel connection between a beam and a wall.?
(that is, without embedding a column in the wall to cheat the system)
Labels (1)
3 REPLIES 3
jay_colcombe
in reply to: chrisd
If you wish to use the Connection Tool you could just use what you have and hide the Column Element out  by of the View.
The only possible alternative is to Create a Custom Connecton from this existing mockup to see if you can place replicate without the need for the embedded element.
Jay Colcombe
Autodesk Certified Instructor
chrisd
in reply to: chrisd
Thanks for your reply @jay_colcombe
I was able to make a custom connection detail which included the panel cast in plate that I can attach to the end of the beam..it works well..! Now I just need to create some more versions of it for different sized steel beams.
The only glitch is that when the connection is applied, the beam extends itself to the centreline of the panel wall rather than staying cut-back from the face of the wall where it started. Not sure if there is any way to avoid this.?
Cheers!
Ignus.E
in reply to: chrisd
Hi. Thats because the changes to a fabrication part when you apply the connection and therefore extend to the system line length.  It does not adhere to the previous cut length.  So either you would have to build in a modifier in your custom connection to trim the beam back again or you would need to model the beam with the system line to the face of the wall and nit the centre before you apply the connection
Forma Design Contest
