Steel Beam Connection to Concrete Column
dzkt98
Message 1 of 8
dzkt98
hello everyone, have anybody created this type of family or connection for this connection? this is I steel beam seat on concrete column, please share me some idea, im stucking with this. thank you
Accepted solutions (3)
Replies (7)
Message 2 of 8
jay_colcombe
There is an Embed beam seat which could give you a starting point and then you would need to customise this to add additional plates etc to get the exact connection as shown in your image of alternatively create it from using the Steel Tab and use individual elements
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 8
JeandreVDM
Hi @dzkt98
Have a look at this short video. You can create your own plates and bolts.
https://www.youtube.com/shorts/nSMwQdt3i3U
Message 4 of 8
dzkt98
thank you
Message 5 of 8
dzkt98
thank you, for further steel knowledge in revit, i created custom steel beam family that has difference section changed, but when i loaded in my project, these are no connection behavior completed. i refered to defaut steel beam to setting up the new custom steel beam but it didn't work. i dont understand why. please take a look at my screen record.
Message 6 of 8
Ignus.E
Hi. Unfortunately Revit steel connections does not support tapered beams and columns. It is on the roadmap, but I think it will still be a while
Message 7 of 8
jay_colcombe
@Ignus.E is correct as regards Tapered Beams
"Connected element not supported ..." when applying a connection or a weld on a beam in Revit
Jay Colcombe
Message 8 of 8
dzkt98
thank you everyone
