Wall with edge on top
baraboutis
baraboutis
Hello, im trying to create the following wall as seen in this section.
What would be the best way to create this?
jay_colcombe
The simplest would be Model In-Place Sweep as it allows you to pick a path and sketch the profile manually but some do not like method!!!
You could use Wall Sweep Tool a Wall and then using a Wall Sweep with a Profile for the wider area!
You could also use a Sweep in the Wall Profile directly and sav the Wall Style for multiple applications
Jay Colcombe
Autodesk Certified Instructor
