When I place a steel connection the default material for plates seems to be "Steel - Carbon" which doesn't make sense. Can I adjust the default setting somewhere? I tried to open the connection family in browser, but I can't edit it.
I can press tab to select the plates and manually change to the material, but if I have multiple connections it is tiring.
Hello @Anonymous
This is a huge problem! Even if you assign a default material in Object Styles, it doesn't work. What we do is to filter all plates, select them and then manually change the material.
Can Autodesk please fix the assignment of materials to steel connections!!!
I have created an Idea for this issue:
https://forums.autodesk.com/t5/revit-ideas/steel-connection-material/idi-p/9181608
