Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
RVT 2020 - steel connection - structural material steel carbon
4 REPLIES 4
851 Views, 4 Replies
When I place a steel connection the default material for plates seems to be "Steel - Carbon" which doesn't make sense. Can I adjust the default setting somewhere? I tried to open the connection family in browser, but I can't edit it.
I can press tab to select the plates and manually change to the material, but if I have multiple connections it is tiring.
4 REPLIES 4
sampie
Hello @Anonymous
This is a huge problem! Even if you assign a default material in Object Styles, it doesn't work. What we do is to filter all plates, select them and then manually change the material.
Kind Regards,
Sampie
_______________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
youtube.com/prokonbuild
sampie
in reply to: sampie
Can Autodesk please fix the assignment of materials to steel connections!!!
Kind Regards,
Sampie
Gernot.Jeromin
in reply to: sampie
we will have a look at it.
Gernot
sampie
in reply to: Gernot.Jeromin
I have created an Idea for this issue:
https://forums.autodesk.com/t5/revit-ideas/steel-connection-material/idi-p/9181608
Kind Regards,
Sampie
Forma Design Contest
Technology Administrators
