Does anyone here encountered the problem of Autodesk supplied Rebar Shape Family Shape Code 67, it's Dimension C is not working
If yes, how did you fix it?
Solved by jay_colcombe. Go to Solution.
I cannot repeat this here unfortunately.
I can only suggest you try and reinstall the Shape from the Library to ensure you have the latest version.
Ok I will do that
Thank you for the suggestion
Ok I will do that
Can I have the copy of your Shape Code 67 if that is ok with you?
Thank you in advance
I am only using Revit 2025, but sure.
Thank you
I will be keeping this for now because I still do not have Revit 2024, let alone Revit 2025
Thank you
