Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit Family's Rebar Shape Code 67 Problem (BS8666:2020)
5 REPLIES 5
Albert.Maduro
274 Views, 5 Replies
Does anyone here encountered the problem of Autodesk supplied Rebar Shape Family Shape Code 67, it's Dimension C is not working
If yes, how did you fix it?
5 REPLIES 5
I cannot repeat this here unfortunately.
I can only suggest you try and reinstall the Shape from the Library to ensure you have the latest version.
Jay Colcombe
Autodesk Certified Instructor
Ok I will do that
Thank you for the suggestion
Can I have the copy of your Shape Code 67 if that is ok with you?
Thank you in advance
I am only using Revit 2025, but sure.
Jay Colcombe
Thank you
I will be keeping this for now because I still do not have Revit 2024, let alone Revit 2025
