Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit 2024 Analytical model not showing
9 REPLIES 9
Message 1 of 10
cf210109
1039 Views, 9 Replies
Hi, I'm a civil student using Revit 2024. I'm trying to assign load to my structure model. And so, i duplicated my structural plans and change the template properties to analytical. But, unfortunately my analytical model is not showing. i have checked and override the properties in V/G but still, the analytical model is not showing. I really need some help here.
9 REPLIES 9
Message 2 of 10
jay_colcombe
in reply to: cf210109
Revit 2023 and 2024 works differently as regards Physical and Analytical model and you now have to use the Analyse Tab > Analytical Automation to create the Analytical Model from Physical elements and vice-versa.
Revit 2023: New workflow for structural analysis (youtube.com)
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 10
cf210109
My problem has been solved, thanks !
Message 4 of 10
21821343
Good Afternoon everyone, I'm trying to use the Analytical Automation feature on revit 2024 but it is grayed out and I'm not sure what the problem is? Any assistance would be appreciated
Message 5 of 10
jay_colcombe
in reply to: 21821343
Is it open and outside the View or on another Screen?
Analytical Automation greyed out in Revit, icon shown on Taskbar
Jay Colcombe
Message 6 of 10
21821343
in reply to: jay_colcombe
It's not even appearing on my Taskbar
Message 7 of 10
jay_colcombe
Do you have Dynamo Installed?  It should be installed as part of the overall installation.
Manage Tab > Visual Programming > Dynamo
Jay Colcombe
Message 8 of 10
21821343
Yes I have Dynamo installed as well
Message 9 of 10
jay_colcombe
Try opening Dynamo Player
Do you have the Samples and can you RUN any of them?
Then try to open from - C:\ProgramData\Autodesk\RVT 2025\Dynamo\Samples\en-GB\Revit\AnalyticalAutomation
Jay Colcombe
Message 10 of 10
jay_colcombe
Also check if you have ALL updates for Revit installed!!
Jay Colcombe
