Revit 2024 Analytical model not showing
cf210109
cf210109
Hi, I'm a civil student using Revit 2024. I'm trying to assign load to my structure model. And so, i duplicated my structural plans and change the template properties to analytical. But, unfortunately my analytical model is not showing. i have checked and override the properties in V/G but still, the analytical model is not showing. I really need some help here.
Replies (9)
jay_colcombe
Revit 2023 and 2024 works differently as regards Physical and Analytical model and you now have to use the Analyse Tab > Analytical Automation to create the Analytical Model from Physical elements and vice-versa.
Revit 2023: New workflow for structural analysis (youtube.com)
Jay Colcombe
Autodesk Certified Instructor
cf210109
My problem has been solved, thanks !
Observer
Observer
Good Afternoon everyone, I'm trying to use the Analytical Automation feature on revit 2024 but it is grayed out and I'm not sure what the problem is? Any assistance would be appreciated
jay_colcombe
Is it open and outside the View or on another Screen?
Analytical Automation greyed out in Revit, icon shown on Taskbar
Jay Colcombe
Observer
Observer
It's not even appearing on my Taskbar
jay_colcombe
Do you have Dynamo Installed?  It should be installed as part of the overall installation.
Manage Tab > Visual Programming > Dynamo
Jay Colcombe
Observer
Observer
Yes I have Dynamo installed as well
jay_colcombe
Try opening Dynamo Player
Do you have the Samples and can you RUN any of them?
Then try to open from - C:\ProgramData\Autodesk\RVT 2025\Dynamo\Samples\en-GB\Revit\AnalyticalAutomation
Jay Colcombe
jay_colcombe
Also check if you have ALL updates for Revit installed!!
Jay Colcombe
