Repeat Causing Generic Models to Flip
J_Rains
J_Rains
I am attempting to create a family for Amphenol's Cable Link system. While using the repeat function in an adaptive family, the models begin to flip by 180 degrees. I have tried every setting for the "Orients to" parameter belonging to the adaptive points in the nested families, however nothing changes. The model is a bit crude, but this is preliminary. Any suggestions?
rosie_lucas1
Hi @J_Rains,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Rosie | Community Manager
J_Rains
Hi, I have not yet found a solution. Thanks for checking in.
jay_colc
Hi have you explored the options for the Node Alignments and possibly using Host driven options?
Jay Colcombe
Autodesk Certified Instructor
J_Rains
Thank you for asking, yes I have tried every option for the node alignment to no avail unfortunately.
jay_colc
Is the Orientation in the imported Family conflicting with the Adaptive Line Family?
I found this which may offer some guindance?
Solved: Repeated Adaptive Component Orientation - Autodesk Community
Jay Colcombe
