Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Remove CAD import from revit family
5 REPLIES 5
muhammad.ihsanX9ZE9
809 Views, 5 Replies
I created custom revit family, I imported CAD to my family project. I can't select the CAD element to move or delete it. Any suggestion for me?
5 REPLIES 5
Hi @muhammad.ihsanX9ZE9
Go to the created family, check these options, you can find them at the bottom rigth.
You can also find it in the upper left corner.
Jamhmer Oc
Could you clarify whether the CAD was used just for an underlay? Or are you using the CAD as part of the family model as well?
not clear? if you imported your cad in your custom revit family then you need to edit your family and delete from there? thanks
case closed, anyway thank you so much.
yaa, just for underlay
Forma Design Contest
