I created custom revit family, I imported CAD to my family project. I can't select the CAD element to move or delete it. Any suggestion for me?
Solved by Jamhmer_Oc. Go to Solution.
Go to the created family, check these options, you can find them at the bottom rigth.
You can also find it in the upper left corner.
Jamhmer Oc
Could you clarify whether the CAD was used just for an underlay? Or are you using the CAD as part of the family model as well?
not clear? if you imported your cad in your custom revit family then you need to edit your family and delete from there? thanks
