Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar Schedules sum
21 REPLIES 21
Message 1 of 22
2523 Views, 21 Replies
Rebar Schedules sum
what's the procedure to calculate all masses in rebar schedule table???
Regards!
21 REPLIES 21
Message 2 of 22
aleksei.tkachenko
Hello
Try to follow steps provided below
Message 3 of 22
in reply to: aleksei.tkachenko
Hi Aleksei,
thanks again for a quick response!!! I did what you suggested and it works ok!
I see now Grand total for "Each bar length" and "Total bar length"! But what I want is total kg???
How can I do this?
Best regards!
Message 4 of 22
aleksei.tkachenko
You are welcome!
You need to create Calculated Value with formula ash shown below
As for Mass per length parameter, depending on project template that you are using, it can be found in Rebar type. If it is not there, you have to create this parameter manually in Manage -> Projcet parameters
Message 5 of 22
Ok, thank you!
I managed to create Mass per Unit Length in Project Parameters:
and than insterted the column in Rebar Schedules with "Calculate totals":
but there are 0,00 kg/m values:
Where did I get it wrong?
Message 6 of 22
aleksei.tkachenko
I see, but have you inserted values for different bar diameters?
Message 7 of 22
Of course I didn't, but my "Type Properties" menu looks different. There is no such cell "Mass per Length"???
Message 8 of 22
OK,...this one is weird,...
I found "Mass per Unit Length" under Properties but it is "Rebar Number" related!!! Seams I have to go bar by bar and manually insert this value (very time consuming)??? Is there some other way,...I'm using Revit 2018!!!!
Message 9 of 22
aleksei.tkachenko
When you create this parameter, you need to choose type, not instance
Message 10 of 22
Thank you! Finally I have this parameter:
How do I get the calculated value you mentioned before (in your first post) - "Total bar Weight"??? I do not see this on the list:
You add something (but what?) from the left side of the menu ("Available fields") and then modify it (add the formula you have on the screen shot - fx icon)???
Message 11 of 22
aleksei.tkachenko
No. Simply push here and type in name and formula
Message 12 of 22
I'm stuck now with weird values,...
after the above formula,....even yours Quantity*BarLength*MassperUnitLength shows the same value!!! Take a look at the last column!
What did I get wrong?
Message 13 of 22
finally managed to figure out where the problem was! I didn't change the value to "calculate totals" in drop down menu!!!
Thank you again Aleksei! You really helped me a lot with this post!
Message 14 of 22
one more thing that bothers me! I cut the table (Rebar's Schedule) in segments to fit A4 format paper. I would like to have "Grand totals" on the last page that summons all rebar's masses (from page 1 to ...)??? Obviously, on the last page, I have "Grand totals" only for Rebar Numbers that are on that page!
Is there a way to achieve this in Revit?
Regards!
Message 15 of 22
does anyone know the solution for the last post?
Any help would be highly appreciated!
Regards!
Message 16 of 22
aleksei.tkachenko
Hello
I'm sure there is a smart solution to your problem. I can suggest only temporary one. Use filters to create separate schedules that fits the ark.
For example
Filter by: Rebar number is greater than or equal to 01
And: Rebar number is less than or equal to 06
Message 17 of 22
Hi Aleksei,
maybe I misunderstood something but if I filter by "Rebar Number" (form 01-06) and check "Grand totals" then Revit will show only grand totals for Rebar Numbers 01 to 06!!! This is what I have now.....five pages (A4 format) filtered by Rebar Number.
But how could I insert Grand totals on the last page for all Rebar Numbers???
Thanks for your time!
Message 18 of 22
Create one schedule, don't use filter, use schedule break to break it to several pieces. Keep one on sheet and drag others to the right side of the sheet, remember, right side, very important detail to keep them outside of the print area. Repeat for all other sheets until you have one piece on each sheet. That's it, you can have the grand total on the last piece of the schedule.
Message 19 of 22
in reply to: ToanDN
Thank you ToanDN,
Excellent tip!!!
You said "create one schedule"! So, when I create only one schedule, and 10 sheets...,....moving schedule on one sheet consequently moves schedule on all other sheets and then I'm in trouble with printing area. As you stressed in your post "everything has to be on the right side"!!!???
Did I misunderstood something!?
Message 20 of 22
@Anonymous
My apology.  You do have to duplicate the schedule.  But you don't need to filter them, just break them.  See attached files.
When print, choose Offset from Corner.
Forma Design Contest
