Rebar Placement Issue: Top Layer Extending Beyond Slab with Structural Area Reinforcement
TasnimTarannum
TasnimTarannum
I am attempting to place rebar on the slab using 'Structural Area Reinforcement', but I'm encountering an issue where the top layer of the rebar extends beyond the slab or its host.System tray overflow window. 2024-03-15 02.42.46.png
Ahmed_M_Heteba
can you check if there any additional offset is applied
if not please try to share the file.
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
TasnimTarannum
No, but the floor has a height ofset of 50mm
Ahmed_M_Heteba
can you share this part of the file which has the issue?
TasnimTarannum
Sure, Kindly Check the red colored slab of the section view.
Ahmed_M_Heteba
It seems like a bug in your slab.
I draw a new slab with same level and offset and it worked fine try to delete and redraw if not worked.
you can use top add offset as a work around check below screen shoot.
awes
Select slab and push button "Reset shape"
