Turning point cloud off from revit file without opening it
Albert.Maduro
Albert.Maduro
Good Day to all
Just want to ask your help if there is a way for a point cloud to be turn off inside revit without opening the revit?
I have a model that contains large size point cloud, opening them first time really takes time
I am hoping to turn the point cloud off without opening the revit?
Thank you
L.Maas
If you work with workshared central file. Then put it on a separate workset and set that workset to not opened. Then you only have to open it when you set it up.
Louis
Please mention Revit version, especially when uploading Revit files.
ctm_mka
Louis;s solution is the best long term. However, if you cannot get into the Revit model to start with, i suggest either temporarily moving or renaming the point cloud file so Revit cannot load it.
