I have a perimetral fence which have elevation variations along all of its lenght, and I need to place the foundation for the posts, my question is that if there is a way to define the path to follow for the footings to place them at the correct elevation to not have to place them one by one
Solved by apjones. Go to Solution.
you will need a dynamo script not applicable by pure Revit as i know.
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
How many footings are there? It's tedious but there are number of ways to do it. I would personally just cut a section (like you've done) after placing all footings in on plan, and then manually offset them one by one from the ground level.
