Hi guys,
I couldn't find anything on this anywhere so maybe you could help.
I need to schedule railing for staircase (total length), however for multistory staircases the schedule counts only the first level and ignores levels above.
Yes, I tried to itemize every instance and count totals.
thank you
Hello, did you try to calculate total for Length? On the Formatting tab in the schedule
yes, still it doesnt do it. It does it for railings on slab, adds them up, but not for multistory staircase. I created separate file with nothing only staircase just to test it and it still counts only 1st set.
Thank you for explanation.
Well I hope this will be fixed in next release or at least there should be a notification. In a project where you have hundreds of meters of railing and realise that you are actually missing another hundred meters can be fairly big issue.
