Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
railing schedule for multistory stairs
4 REPLIES 4
Karol_Piroska
870 Views, 4 Replies
Hi guys,
I couldn't find anything on this anywhere so maybe you could help.
I need to schedule railing for staircase (total length), however for multistory staircases the schedule counts only the first level and ignores levels above.
Yes, I tried to itemize every instance and count totals.
thank you
4 REPLIES 4
jachyme
in reply to: Karol_Piroska
Hello, did you try to calculate total for Length? On the Formatting tab in the schedule
Ewa Jachym
Principal User Experience Designer
Karol_Piroska
in reply to: jachyme
yes, still it doesnt do it. It does it for railings on slab, adds them up, but not for multistory staircase. I created separate file with nothing only staircase just to test it and it still counts only 1st set.
jachyme
Oh I see, Railings defined on multistory staircase are grouped and count as a one element with the same length . So unfortunately there is no easy workaround except maybe adding additional parameter as a quantity to the schedule.
Ewa Jachym
Karol_Piroska
Thank you for explanation.
Well I hope this will be fixed in next release or at least there should be a notification. In a project where you have hundreds of meters of railing and realise that you are actually missing another hundred meters can be fairly big issue.
