Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Problem with Generic Model from IFC
1 REPLY 1
jpizarroSE564
408 Views, 1 Reply
Hi everyone:
Currently on my  job we are working with Revit to add the structural rebars to concrete elements, the working flow is the following:
Modeling  of  solids (footings, slabs, columns, etc.):  AVEVA E3D
then the modeled elementsare exported to REVIT via IFC, as Generic models (to avoid further modifications)
Then the generic models are added with structural rebars.
The problem is:  some elements that have voids, or empty spaces, revit doesn´t recognize them properly as generic models and cannot be editted or select the edges, faces or joints (only select the entire element ). is there a way to solve this issue?
i attached a file with an example
1 REPLY 1
mphungDCHNW
in reply to: jpizarroSE564
I am pretty sure if you created a round edge with a fillet in a generic model Revit will show it as how it is. if your worried about it not showing you can always add a void extrusion within the generic model of the shape you want.
Forma Design Contest
Technology Administrators
