Hi everyone:
Currently on my job we are working with Revit to add the structural rebars to concrete elements, the working flow is the following:
Modeling of solids (footings, slabs, columns, etc.): AVEVA E3D
then the modeled elementsare exported to REVIT via IFC, as Generic models (to avoid further modifications)
Then the generic models are added with structural rebars.
The problem is: some elements that have voids, or empty spaces, revit doesn´t recognize them properly as generic models and cannot be editted or select the edges, faces or joints (only select the entire element ). is there a way to solve this issue?
i attached a file with an example
