Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Precast reinforcement not working
9 REPLIES 9
Message 1 of 10
kari_rinne
433 Views, 9 Replies
I am trying to add reinforcement with precast to the wall I already split previously. However when I do it it just tells me that an error happened and I should report the issue. What should I do?
9 REPLIES 9
Message 2 of 10
jay_colcombe
in reply to: kari_rinne
This is old fix but it could still be relevant;
Workaround:
Turn off Precast before making any modifications
"An error was encountered while trying to update the Precast Elements" in Revit (autodesk.com)
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 10
kari_rinne
in reply to: jay_colcombe
It doesn't seem to change anything unfortunately. I did it but I still get the same error message
Message 4 of 10
jay_colcombe
I would assume it is related to the Panel with the opening?
Can you create the opening a different way such as the Structural Opening Tool or splitting then Editing the Assembly with the opening.
can you share the model for checking?
Jay Colcombe
Message 5 of 10
podaruc
Hi  kari_rinne,
I would like to investigate this issue. For this, I need to take a  look at the project where this occurs. You can attach the file here, or if  attaching it here is not possible, I can contact you and figure out the next steps. Is this ok?
Cristian
Cristian Podaru
Sr. QA Analyst
Message 6 of 10
kari_rinne
The issue occurs with all the panels in the walls. I attached the model. The view in the picture is SEINÄ 1. If the model seems bad, I am still just practicing Revit
Message 7 of 10
podaruc
Thank you for attaching the model. We will investigate it, and will come with updates as soon as possible.
Cristian
Cristian Podaru
Sr. QA Analyst
Message 8 of 10
jay_colcombe
The issue appears to the the Top Left Panel and the small step in the bottom comer when trying to edit this part I get the following error
Jay Colcombe
Message 9 of 10
jay_colcombe
I did get a warning about edge reinforcement with the other panels but reloading the components fixed this so this would be related to the specification used
Jay Colcombe
Message 10 of 10
kari_rinne
I deleted the step that I didn't even notice previously (and wasn't supposed to be there) and now it works. Thank you very much!
Forma Design Contest
Technology Administrators
