Revit Structure Forum
Welcome to Autodeskā€™s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Please help i got a problem with graphics
8 REPLIES 8
Message 1 of 9
liwanagmalikz
374 Views, 8 Replies
there was like a shadow on the floor every time I pan around the shadow moving revit.png
8 REPLIES 8
Message 2 of 9
shadow off or try to uncheck your use hardware acceleration from options and see if helps. thanks
Message 3 of 9
it's off
Message 4 of 9
how about uncheck use hardware acceleration from options? or delete your current 3D view and create a new one and see if helps. thanks
Message 5 of 9
still got the problem
Message 6 of 9
can you share the file so we can check? and try to update your graphics driver to the latest and see if helps and install latest updates from autodesk.. thanks thanks
Message 7 of 9
here is the file thanks
Message 8 of 9
okay, just select your floor and untick enable analytical model. thanks
Message 9 of 9
OMG thank you very much!!!!šŸ™ŒšŸ™ŒšŸ™Œ
Forma Design Contest
Technology Administrators
