there was like a shadow on the floor every time I pan around the shadow moving
Solved by ennujozlagam. Go to Solution.
shadow off or try to uncheck your use hardware acceleration from options and see if helps. thanks
how about uncheck use hardware acceleration from options? or delete your current 3D view and create a new one and see if helps. thanks
can you share the file so we can check? and try to update your graphics driver to the latest and see if helps and install latest updates from autodesk.. thanks thanks
okay, just select your floor and untick enable analytical model. thanks
