Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
parallel chord truss web members
2 REPLIES 2
KyleWynia
196 Views, 2 Replies
Every time I place a parallel chord truss it seems to do whatever it wants. However no matter what I try the web members seem to show up incorrect. Could someone please tell me what I am doing wrong when placing these trusses?
2 REPLIES 2
Tom_Kunsman
in reply to: KyleWynia
What was the last structural member that you modeled before placing the truss? Revit will use that when the truss gets placed. Take a look at the Type properties for that truss and make sure each of the members has the correct member associated with it.
Did you try resetting the truss profile? (Select truss and option will be in ribbon)
KyleWynia
in reply to: Tom_Kunsman
Yes the problem was with the members I was using. Because the member had a dropline associated to it, the member was being inserted in the member incorrectly. I created a new member with no dropline and it works fine now.
Forma Design Contest
