Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Beams weight (Revit LT)
4 REPLIES 4
sallaliE6WHH
289 Views, 4 Replies
I'm trying to get the weight of beams for a schedule but the weight parameter is empty
Someone here explained that it is related to the fabrication shape to get the extra parameters and suggested to apply some commands from Steel Tab to the element to get the extra parameters (since they are added automatically when applying any commands from the Steel Tab) but I'm using Revit LT and I don't have the Steel Tab.
any suggestions how to solve this ? Thanks.
4 REPLIES 4
in reply to: sallaliE6WHH
Try material take off schedule.
sallaliE6WHH
in reply to: ToanDN
I tried, it's also empty there
This parameter is empty either you follow material weight as @ToanDN  suggested or you define a formula for weight by yourself as shared parameter or calculated parameter
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Forma Design Contest
