Is there any way to generate NC files for steel beams for CNC processing from Revit? The current procedure is to export IFC to Tekla and rework everything there, then generate NC files. Advance Steel has proven to be even worse at this than Tekla. I'm not very familiar with Revit, so I'm not sure about it's abilities to create dxf/nc files with all the markings and holes and cuts displayed on the correct layers.
I have attached the basic NC file output from Advance Steel that we're trying to generate from Revit.
