Halftone Line
Halftone Line
Message 1 of 14
Halftone Line
I have one line style I would like to be halftone.  I can do it by selecting each line and editing in override graphics in view by element.  I don't want to have to do that for each job. I'd like it set in my template.  this one line type needs to always be halftone.
Any ideas?
Thank you!
Replies (13)
Message 2 of 14
awes
Use light gray color in template file?
Message 3 of 14
I use that but when your printer setting color is set to black lines it doesn't help much.
or do you print using color gray scale?
Message 4 of 14
revitnation
Consider creating a Selection Filter. You can then add the Selection Filter to multiple View Templates with this powerful Add-In. It is well worth the money for working on large complex projects. https://apps.autodesk.com/RVT/en/Detail/Index?id=6434143480366085343&ln=en&os=Win64 Hope this helps!
Message 5 of 14
PavelAnd
Hi @Anonymous. You can use Dynamo.
Best regards, Pavel Plotitsyn.
Message 6 of 14
thank you,
I haven't been using dynamo.  The little I play with it i don't understand it.  Do you have an suggestions for newbie training classes.
Message 7 of 14
WEC17
on your template go to manage/additional settings/line styles. Click on new tab and create a new line style assign the color you want and the line weight and you be done. This line will be available any time you need it.
Message 8 of 14
Pkelley
Did you ever figure out how to create a halftone line style?  If so, please share.
Message 9 of 14
RFreund
Is there a reason this can't be changed in the view filter?
Message 10 of 14
jeremy.colombe
Any solve this? Overriding to halftone is not ideal.
Message 11 of 14
Pkelley
Instead of trying to make a black line plot halftone I created a new "gray" line using the color I want the line to plot as.
Message 12 of 14
jeremy.colombe
I tried that but it still printed dark. I tried 252 gray and the other 152 or wahtever it is. The only way to get the "faded" look was to override as halftone.
Message 13 of 14
Pkelley
I use pen 129 for gray and 192 for light gray. You may need to experiment to find the right shade.
[cid:image001.jpg@01DBF641.5B7E69C0]
Message 14 of 14
jeremy.colombe
Cool I will try a bunch and report back
