Halftone Line
Halftone Line
不适用
7,728 次查看
13 条回复
1 条消息(共 14 条)
Halftone Line
不适用
I have one line style I would like to be halftone.  I can do it by selecting each line and editing in override graphics in view by element.  I don't want to have to do that for each job. I'd like it set in my template.  this one line type needs to always be halftone.
Any ideas?
Thank you!
0 个赞
已接受的解答 (2)
7,729 次查看
13 条回复
回复 (13)
2 条消息(共 14 条)
awes
Use light gray color in template file?
0 个赞
3 条消息(共 14 条)
不适用
I use that but when your printer setting color is set to black lines it doesn't help much.
or do you print using color gray scale?
0 个赞
4 条消息(共 14 条)
revitnation
Consider creating a Selection Filter. You can then add the Selection Filter to multiple View Templates with this powerful Add-In. It is well worth the money for working on large complex projects. https://apps.autodesk.com/RVT/en/Detail/Index?id=6434143480366085343&ln=en&os=Win64 Hope this helps!
0 个赞
5 条消息(共 14 条)
PavelAnd
已接受的解答
Hi @Anonymous. You can use Dynamo.
Best regards, Pavel Plotitsyn.
0 个赞
6 条消息(共 14 条)
不适用
thank you,
I haven't been using dynamo.  The little I play with it i don't understand it.  Do you have an suggestions for newbie training classes.
0 个赞
7 条消息(共 14 条)
WEC17
已接受的解答
on your template go to manage/additional settings/line styles. Click on new tab and create a new line style assign the color you want and the line weight and you be done. This line will be available any time you need it.
0 个赞
8 条消息(共 14 条)
Pkelley
Did you ever figure out how to create a halftone line style?  If so, please share.
0 个赞
9 条消息(共 14 条)
RFreund
Is there a reason this can't be changed in the view filter?
0 个赞
10 条消息(共 14 条)
jeremy.colombe
Any solve this? Overriding to halftone is not ideal.
0 个赞
11 条消息(共 14 条)
Pkelley
Instead of trying to make a black line plot halftone I created a new "gray" line using the color I want the line to plot as.
0 个赞
12 条消息(共 14 条)
jeremy.colombe
I tried that but it still printed dark. I tried 252 gray and the other 152 or wahtever it is. The only way to get the "faded" look was to override as halftone.
0 个赞
13 条消息(共 14 条)
Pkelley
I use pen 129 for gray and 192 for light gray. You may need to experiment to find the right shade.
[cid:image001.jpg@01DBF641.5B7E69C0]
0 个赞
14 条消息(共 14 条)
jeremy.colombe
Cool I will try a bunch and report back
0 个赞
