No analytical model when I import a model from IFC data
Hello Everyone,
I am struggling to convert an IFC model to an Analytical model in Revit.
[ How to convert model ]
- The model was opened in a structural template.
- opened from "File→open→IFC". "link" was not used.
- The Elements which I want to use as structural elements were imported as "Structural Columns" or "Structural Framing" or "Structural Beam Systems"
The model was successfully imported as a 3D model, however, nothing showed up in the Analytical model view...
When I clicked the column, it says "I am a Structural Column".
So I was thinking, theoretically, It should show up also in the Analytical model...
I think the way how I imported IFC data should have a problem...
Please give me a tip to solve my problem...!
Jamhmer_Oc
Hi @Anonymous
When I open the attached file and select the item, it is an in-place model so it will not have an analytical model.
You will have to create the analytical model, but it is a lot of work.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/415...
Jamhmer Oc
Hello @Jamhmer_Oc
Thank you for your answer!
I watched the video from the link which you attached.
Yes... It looks like a lot of work if I will do it for all elements...
Soooo.. Is it impossible to import the elements with analytical lines from IFC data automatically??
Is it still not supported as a function ??
I was thinking it is not that so difficult to generate the analytical lines from the imported model in Revit, as I can do it in other software...
Best,
Emi
Jamhmer_Oc
Unfortunately, Revit natively will not be able to do it.
Jamhmer Oc
Hi @Jamhmer_Oc
wow...It is sad news...however it was nice to know it.
I was believing that Revit is the best software to integrate the workflow through IFC data, also for structural analysis...
Thanks a lot for your advice 🙂
mm1452
@Anonymous @Jamhmer_Oc
Hi all,
Hope this helps you
https://apps.autodesk.com/RVT/en/Detail/Index?id=7027225957132158422&appLang=en&os=Win64
https://www.youtube.com/watch?v=bORyKNborfo
I developed it for the same reason in my work and I think it will help you also.
Best Regards
Micheal
