Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Moving or copying in 3D environment
13 REPLIES 13
Message 1 of 14
ksekhavati
1012 Views, 13 Replies
I have drawn a wall in 3D with 2 ledges as shown in position 1. One ledge in near face of wall and one in the far face. I have 2 questions:
  1. When I copy the wall randomly from position 1 to position 2, the far face ledge jumps up to top of wall as you can see in position 2.
  2. When I want to copy the wall, none of the snaps work in 3D. I tried to draw a detail line in the bottom left hand side of wall so that I can pick the end of line as my picking point the detail panel on the annotate ribbon is greyed out. In general I find it hard to use the snaps in 3D environment for moving or copying objects. Any help would be greatly appreciated.
13 REPLIES 13
Message 2 of 14
L.Maas
in reply to: ksekhavati
I rarely do modeling work in 3D views (Revit is not optimal to work in those views). Most of the modelling I do in floorplan/ceiling views or sections/elevations. Much better control over positioning in those views.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 14
ksekhavati
in reply to: L.Maas
you may be right, but I still would like to know the answer to my question please
Message 4 of 14
L.Maas
Can you post the file so that we can see what you have done the screenshot does not give a lot of information
Which version of Revit are you using?
When I copy (using regular copy, not the clipboard copy) a wall I see snap points. The destination snap point will also appear if it is a valid position (I can copy in the same plane, not vertically)
Louis
Message 5 of 14
Using the shift key will help keep the object at the same level as long as you have the original one set to a level. When copying in 3D view Revit does not take the Z coordinates into consideration and will place it at any point on the Z plane.
Message 6 of 14
ksekhavati
in reply to: L.Maas
Hi Lou. sorry for the late reply. my internet was playing up. can you please let me have your e-mail address or tell how to attach files with messages here. I know how to add images here but not files.
Message 7 of 14
ksekhavati
I tried that with no joy. I'll keep trying. Thanks anyway
Message 8 of 14
ksekhavati
in reply to: L.Maas
sorry I forgot to mention i am using 2021 version of revit
Message 9 of 14
L.Maas
If you have problems with uploading here, than use a service like WeTransfer.
Louis
Message 10 of 14
ksekhavati
Hi. I tried to use the we transfer web site, but it still is asking me for the recipient email address
Message 11 of 14
ksekhavati
Message 12 of 14
Just attach it here:
Message 13 of 14
ksekhavati
in reply to: ToanDN
Thanks a lot for that. got it.
Message 14 of 14
ksekhavati
Please find attached the file requested.
