Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Hidden Lines Stuctural Framing
4 REPLIES 4
412 Views, 4 Replies
Sorry There, a few times I found this misunderstanding... hidden lines in section for these steel beam, trying to keep   HEA260 hidden lines visible as in this dwg.
Why switching the hidden lines as discipline and discipline structural i cannot see the finish of the steel cut lenght extendend as dashed line inside this concrete wall? if you see the second image is my mouse staring on it trying to highlight the view section in reality that is on the first image.
2 question with timber frame structures. Why do my cut geometry on my reference plane gives not a thorough result  ?
4 REPLIES 4
rkhattar
Have you tried switching the join order between timber beams?
Is your steel beam bearing on you RC Wall or fixed to the face of it?
Could also try switching the join order between the RC wall and Steel beam.
in reply to: rkhattar
second question: The steel beam is Primary whereas the concrete w is structural amnd Revit cannot let me switch or Join anything between each other. In this case, in reality the beam should be unfolded on the uppest part of the CWall.
First Question: there is no Join interaction and only NOTCH interaction with these timber beams.. what do you mean?
rkhattar
Q2.
Have you tried the cope function?
Are your joists being placed in a notch in your primary beam?
"Cope" might be the only way to achieve this if "Cut" isn't working.
Do you mean NOTCH? there is no availability to notch a wall with a beam...
Forma Design Contest
