Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Missing UK Columns in library
3 REPLIES 3
cn19jssc
1010 Views, 3 Replies
Hi all,
I am trying to get a UC 203x203x127, but when I load up the UC family it's not there and there is a few other columns that aren't present either. All of the UBs are there. I've tried redownloading the content from here: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/downloads/content/autodes...
I know that I can go and easily edit the properties of another 203x203 column to make the one I want, but it's a bit inconvenient. Anyone know why they don't appear in the family?
3 REPLIES 3
Jamhmer_Oc
in reply to: cn19jssc
Hi @cn19jssc
Check in the following path.
C:\ProgramData\Autodesk\RVT XXXX\Libraries\UK\Structural Columns\Steel\British Standard
Do not forget to activate the option to see hidden items.
Or it may be necessary to reinstall the library.
Jamhmer Oc
RPTHOMAS108
They are here:
C:\ProgramData\Autodesk\RVT 2021\Libraries\UK\Structural Columns\Steel\Corus Advance
Named as UKC-UK, introduced by Corus not part of BS 4 range. Now can be seen in Blue Book marked as additional to BS EN 10365 (uncommon in other words).
cn19jssc
in reply to: RPTHOMAS108
Thank you!
Forma Design Contest
