Hello everyone,
I'm trying to make rebar for a pyramid shaped foundation. The rebar shape is sort of like an inverted “U” , and given the slope of the pyramid, each rebar will be of different length. I’ve been trying to do it with free form rebar without success.
Then I tried to place it by hand, first copying the middle rebars and then resizing it, but then the rebars ends were misaligned. Is there a way to accomplish this?
Thanks in advance!.
Solved by veasnakimbitus. Go to Solution.
Hi @LauB1975 ,
Let try like this:
1. Model rebar by sketch follow your shape.
2. Set correct rebar host and set Varying Rebar Set.
3. Edit Constraints follow your need.
Please download Revit 2024.2 file below.
I hope this may help you.
Thank you.
