Create opening in staircase landing
Hi everybody,
I want to give a  opening in staircase mid landing . we had tried with void family but its not cutting the mid landing slab.
Help us to resolve this issue...
L.Maas
Not a straightforward solution. In THIS blog post an explanation how it can be done
Louis
Please mention Revit version, especially when uploading Revit files.
A_MAQ
Kindly see the attached screen cast , this an easy way to perform what you want
Autodesk Expert Elite
Hi @A_MAQ
      Thanks for ur reply,
          But i want the opening should be in the middle of the midlanding slab.
Hi @L.Maas,
                   Thanks for ur reply for our concern. We already tried this method as what u had mentioned in the blog.
A_MAQ
If I understood you , it's the same you can create it in middle of landing also , it's the same procedure Landing opening.png
jasonmccool8686
That's definitely a workaround in every sense of the word... Yet another reason why any Revit user that's ever had to deal with stairs hates Revit stairs. Working with stairs in Revit is sometimes nothing but workarounds to the OOTB inadequacies of Revit. And here I am 6 years later still dealing with this same shortcoming in Revit.
