Lock parameters
Lock parameters
Lock parameters
Hi guys
Is there a way to lock the parameters that associated with elements, to prevent any changes ?
Regards
BIM.Consultant
Yes. You can do so by writing the value in the formula field. Check following image:
Hi again
can we do that also for system family ?
Thank you
BIM.Consultant
In Revit 2017, you may use global parameters.
Hi
I want to bother you if possible, can you tell more about global parameters ?.
Thank you
BIM.Consultant
Sorry I don't have Revit 2017 on my current machine. You can find short example here: https://www.youtube.com/watch?v=Sb82V0rmANs
